A private VLAN must be created. For more information about creating private VLANs, see Create a Private VLAN.
Assign one I-SID for each private VLAN.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#vlan i-sid 5 75 Switch:1(config)#show vlan private-vlan ======================================================================== PRIVATE VLAN ======================================================================== Primary Primary Secondary Secondary VLAN ISID VLAN ISID ------------------------------------------------------------------------ 5 75 6 75
The following table defines parameters for the vlan i-sid command.
Variable |
Value |
<1-4059> |
Specifies the VLAN ID. Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
<0-16777215> |
Specifies the service instance identifier (I-SID). You cannot use I-SID 0x00ffffff. The system reserves this I-SID to advertise the virtual BMAC in an SMLT dual-homing environment. This value is the same for the primary and secondary VLANs. |
force |
Specifies the software must replace the existing VLAN-to-I-SID mapping, if one exists. |
